94 Z28 LT1 - engine running retarded
Re: 94 Z28 LT1 - engine running retarded
Did you read the timing retard with a scanner? How much knock retard are you getting?
Do you have any codes? DTC 43 for the knock sensor will cause the PCM to use a calculation based on engine operating conditions to pull a variable amount of timing (up to a 15-deg max) at virtually all times.
thanks I am forwarding your questions to the mechanic that's actually doing the work on the car for me.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
