shaving lt1 heads
Old Feb 8, 2013 | 07:13 AM
twistedbowtie's Avatar
shaving lt1 heads
I have tried seaching and cant get what im looking. I have a lt1 with 80k miles. Ran great and im doing a budget build I had a cc306 cam sitting on my self so put it in although its to big. Now the question it I want to have the heads ported when I do I wanted to shave them. How much can I take off without have valve clearence problems. And still run pump gas ? The motor is stock bottom end full bolt ons. Also while the motor is out should I put in arp rod studs?
Thanks Dustyn
Old Feb 8, 2013 | 10:21 AM
Re: shaving lt1 heads
What ratio rocker arms are you using?
Old Feb 8, 2013 | 11:50 AM
I still have to buy a set I wanted to nake sure they would work with whatever set up I go with
Old Feb 8, 2013 | 05:05 PM
Dtimekw's Avatar
Talking Re: shaving lt1 heads
You mentioned a budget build, what exactly are you building? Bottom end, top end, both? What are your goals? There are supporting vendors on here who could probably put a package together, using most of your parts, to build a nice street car. You also said full bolt ons. You may want to add a signature with the bolt ons listed, makes it a little easier for the forum to help you out.
I think most of us would agree that you need to set a goal and a budget, then go from there. With that info, you'll probably get a lot more input from those of us who have been in your shoes and already worked thru the good, bad and ugly of building these cars.
I remember reading on here somewhere and I'll pass it on. There are 3 things to these cars. Speed, reliability and cheap....you only get to pick 2
Old Feb 10, 2013 | 12:52 AM
Thanks man. When I say budget I dont mean cheap out. Ive just got a complete cam swap and headers, 58mm throttle body, full exhaust, built 4l60e with 3000 stall, 36lbs injectors ect. All I really need is head work so it will make decent power. Im probably going to let a local shop hand port them they are pretty cheap and cant afford a high dollar port job. I just was wondering how far I could shave the heads with such a big cam or if anyone has done this before.
Thanks for the help guys.
Old Feb 12, 2013 | 12:39 AM
ACE1252's Avatar
If it were me, I think I'd leave the heads stock until I could afford an LE or AI port job. Since quite a bit of power is in the heads, don't cheap out of them if possible.
I can't address your original question directly, but the safest thing to do would be to check the piston to valve clearance, as the heads are now, with the new cam and that would give you a good idea how far you can go.
Old Feb 12, 2013 | 05:37 PM
Dtimekw's Avatar
+1 Check PTV now, that will help decide how far to shave the heads. Might as well check quench too as this could lead you to a thinner head gasket affecting PTV.
In general though, from all of the recent research I've done lately, your PTV should be fine but always check to be sure.
Old Feb 13, 2013 | 06:48 AM
lt1-xjs's Avatar
The heads already have a small chamber and most only take the minimum off to clean them up, .005-.010. You can raise the compression by using a thinner head gasket.
Old Feb 15, 2013 | 07:56 AM
redline9570's Avatar
Thanks Dustyn
Doing the same build as you, I am going with 280 xfi cam with a stage 3 port and bowl. Ported and matched intake runners with boltons. I want to keep the CR around factory specs which is 10.25-10.5. The guy at the shop said my combo will be close to 450hp. New rear end here I come =), although I seen 10.9s with stock drive train.
Old Feb 15, 2013 | 08:07 AM
RamAir95TA's Avatar
Hate to say it but this is a recipe for disaster. You may want to reconsider your approach and start from scratch. There is so much wrong here it's hard to comprehend. I could go into it but maybe through the search feature you'll be able to find out where you're going and why it is such a poor plan.
Old Feb 15, 2013 | 09:26 AM
Yes, with slicks it would tare many things up.
Old Feb 15, 2013 | 09:49 AM
lt1-xjs's Avatar
They say the stock LT1 can take up to around .620" lift however, milling, changing the head gasket and rocker ratio are all factors of available lift and must be considered. Just do the math.
Old Feb 15, 2013 | 11:14 AM
RamAir95TA's Avatar
I am not just talking about the slicks, I'm talking about every single thing you posted.
Old Feb 15, 2013 | 11:34 AM
Not sure what is wrong with the stage 3 ported 643 heads and the 280 xfi comp cam? People run up to 600 horse with stock bottoms and like I said 10.9s with stock rear and trans. I am sure it's less then ideal and they are running these cars on borrowed time. I don't intend to drag the car but maybe once in a blue moon a little light to light.
oldschool
Feb 9, 2016 09:21 PM
PCLZ28
Dec 24, 2015 05:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
