ad misfire on low rpms
Old Dec 11, 2012 | 06:54 PM
yanal_13's Avatar
1995 z28 6spd
i have this problem when below 2k rpms the car feel shaky if i give a full throttle. i know i have a bad egr and i had a miss fire because of that but it wasnt like that the whole motor and tranny starts shaking and feels like the tranny is gonna fall off. i cant put it on 6th gear i have to keep it on 5th gear on the highway over 2k rpms.
the wire #7 fell off the spark plug before and gave the same thing then few days ago it fell off again and i put back and still have the same problem
i checked the wire it was fine but could it be burnt from the header?
Old Dec 12, 2012 | 07:38 PM
yanal_13's Avatar
Re: ad misfire on low rpms
i found what the misfire from it is the wire #7 is bad and you can the spark coming out from it. i know it is the wire cuz i just changed the spark plug too
Old Dec 17, 2012 | 11:18 AM
mjones60's Avatar
I did the same thing but mine was on the 6 and 8 plugs on the passenger side. I replaced both then realized I had a big leak. The factory elbow coming from the throttle entrance. Waiting for my aftermarket intake elbow to arrive off ebay so i can end these camaro blues.
Old Dec 17, 2012 | 09:17 PM
yanal_13's Avatar
i could actually sea the spark coming out of the wire on the seventh
i put the trick-flow elbow for my car it not bad you will notice better response on mid range
Navecm
Jun 1, 2015 05:57 PM
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
