Advice needed on engine swap 94 z28 swaping 96 engine
Old Feb 9, 2013 | 04:41 PM
oldtimeSS's Avatar
Like the title says I have a 94 camaro z28 I am going to be swaping a motor out of a 96 camaro into the 94. is there anything I need to know that is different or that will give me a hard time and if so what is the solution? I know that mine is the non vented opti and this one is the vented. just trying to get all my ducks in order here. thanks in advance.
Old Feb 9, 2013 | 04:53 PM
bw_hunter's Avatar
Re: Advice needed on engine swap 94 z28 swaping 96 engine
You should do a search on this.there are many threads on what you're looking at doing.
You'll need to swap the short Opti harness and the knock sensor. Just ignore the crank position sensor on the timing cover...your harness doesn't include a provision for it.i believe the EGR is different as is the exhaust...unless you have long tube headers.
Pretty much everything else is the same or close enough.....
Good luck!
Old Feb 9, 2013 | 06:24 PM
oldtimeSS's Avatar
sounds good I will be adding long tube headers so that will solve that. thanks.
Old Feb 9, 2013 | 08:31 PM
EGR is the same. It's the AIR cnnections that are different.
You will also end up with an EVAP vacuum switch on the passenger valve cover that doesn't need to be hooked up.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
cmdeshon
Dec 12, 2014 10:51 PM
chuyz28
Nov 25, 2014 11:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
