97 z28 30th anniversary
Old Jan 12, 2013 | 09:53 AM
johnboyz28's Avatar
lt1 sat for years in car should i rebuild or by a new engine. hooked up to a T56 6 speed manual. has a oil leak from somewhere egr valve is bad among other things first camaro ive owned. engine still has lots of power??? any advice helps
Posted from Camaroz28.com App for Android
Old Jan 13, 2013 | 09:01 AM
Re: 97 z28 30th anniversary
Welcome to CamaroZ28.com !
I'd pull the heads and see what the conditions are before assuming it needs to be rebuilt. Which end of the engine has the oil leak?
Let's copy this to the LT1 Based Engine Tech forum, where you are more likely to get more feedback on your specific questions.
Old Jan 13, 2013 | 10:15 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
How many miles are on the car. I would check things out before I started tearing into it, like compression, fuel pressure etc.
Does the car run? My '94 sat in storage for a long time without any prep. I had put about 100K on it when I stored it. I had to replace a lot of stuff to get it running, but nothing thus far has indicated that the engine needs to be rebuilt.
Old Jan 13, 2013 | 01:15 PM
johnboyz28's Avatar
it has about 80,000 miles it sat from 09 to last year ... does the egr valve play a big part in that as well
Old Jan 13, 2013 | 01:17 PM
johnboyz28's Avatar
yes car runs and drives just hesitant at times i rarely put my foot in it with not knowing if anything is wrong with it
Old Jan 13, 2013 | 01:40 PM
The EGR valve will not affect much unless it's sticking open. If it is open when it's not supposed to be (for example, at idle or above 3500 RPM) the engine may run rough and stumble.
I would check the fuel filter, and try running a high concentration of injector cleaner. Also check the fuel pressure as noted in a post above.
Old Jan 13, 2013 | 01:49 PM
johnboyz28's Avatar
ok ill give that a shot thank you
Old Jan 13, 2013 | 09:15 PM
johnboyz28's Avatar
how do i check fuel pressure?
Old Jan 13, 2013 | 09:29 PM
slick1hunting's Avatar
You check fuel pressure by connecting to the schrader valve located behind intake manifold. Personally I check just with prime and watch to see if it bleeds quickly. I then check at idle then I pull the vacuum line off fpr as that simulates under load. If you dont want to buy one you can "borrow - loan" from orieley and or autozone by putting a deposit down and then get your deposit back upon return. I did notice on one I borrowed it was very sensitive to how I tightened to the schrader(hand tight but not quite as hand tight as I was able) im sure with a search on here you can get better directions. I would assume shoebox has detailed instructions on his site. Bookmark his site because its an incredible help for many situations.
Old Jan 13, 2013 | 10:00 PM
johnboyz28's Avatar
thank you you guys are a lot of help... im going to have a lot of questions first v8 ive had trying to get everything fixed so i can start adding more horse
dgPltt
Feb 11, 2015 07:04 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
rockync7
Jan 1, 2015 05:10 AM
Red97LT1
Sep 7, 2002 09:29 PM
