Engine RPMs slow to drop/hunt when clutch is in.
Old Jan 22, 2013 | 11:48 AM
slyr's Avatar
Hey guys,
This problem is driving me nuts. I have already replaced the throttle position sensor, and now I just replaced the IAC and my RPMs still drop slow with the clutch in or hunt up sometimes to around 2.5 to 3. I feel like I've tried everything. Any help greatly appreciated.
Thanks!
Old Jan 22, 2013 | 03:26 PM
Re: Engine RPMs slow to drop/hunt when clutch is in.
Is this when you are moving or not moving? The computer keeps the RPM up a little until you stop.
Old Jan 24, 2013 | 04:36 AM
slyr's Avatar
Thanks for the reply.
It is both when moving and when not moving, and like I said it can climb up to 3k RPMs. Usually when I come to a stop it will very slowly come down but almost never to normal idle RPMs. Also there are times where it stays high enough that I can let the clutch out and not give it gas - it will drive like an automatic lol.
Old Jan 24, 2013 | 08:30 AM
Have you checked for vacuum leaks?
Old Jan 24, 2013 | 12:46 PM
95 Firehawk's Avatar
^^^^x2
Vacuum leaks or perhaps a sticking throttle body. Verify the TB actually returns to the stop screw when you let off the pedal.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
