Lt1 into Ls1 hole
Old Feb 16, 2013 | 06:11 PM
bozwell's Avatar
Lt1 into Ls1 hole
Im looking to swap a lt1 from a 95 z28 into a 99 z28 that had the ls1.Is this an easy swap.I believe the motor mounts are different.Anybody do this before.thanks boz
Old Feb 16, 2013 | 06:36 PM
redline9570's Avatar
Re: Lt1 into Ls1 hole
Don't do it, stay with the ls1.
Old Feb 16, 2013 | 06:41 PM
bw_hunter's Avatar
Most people go the other way....
You'll want to change the K member as it's different on LS cars....slong with a whole lot more.
Old Feb 16, 2013 | 08:39 PM
97WS6SCharged's Avatar
You're better off getting a LS motor from a JY and using that than trying to isntall an LT1 in that car.
Old Feb 16, 2013 | 10:19 PM
kevhogaz's Avatar
You'd need a k-member, steering rack, steering shaft, return fuel line, an LT1 harness, and a bunch odf other expensive stuff.
With 5.3 truck motors a dime a dozen, why bother?
Old Feb 17, 2013 | 12:55 AM
Catmaigne's Avatar
I would do it for shock value. It could only get better if you swapped an old flat tappet SBC motor with Edelcrap parts into it.
Old Feb 17, 2013 | 06:10 AM
bozwell's Avatar
the 5.3 ls motor would be a lot easier ?
Old Feb 17, 2013 | 07:45 AM
6.0? If you had an ls motor in there stay with the ls as for the 5.3, just listen to what she said, bigger is better go 6.0.
Old Feb 21, 2013 | 06:23 PM
OneShoe50's Avatar
Be careful, if you have to pass a visual test for emissions and the tech knows the difference between an LS and a LT, and that a 99 should have an LS, they may refuse to test it. Some states you can put in a newer engine in a older car, but not an older engine in a newer car. Just sayin'.
Build the LS, less hassle, more power.
Old Feb 22, 2013 | 11:14 PM
Considering you can get 5.3s for dirt cheap and it's pretty much a direct swap, yes. If you can find a decent 6.0 for a good price then go for it but otherwise a 5.3 will work well enough. They also respond very well to nitrous or boost and you can bore the iron block to a 3.095 bore (5.7L) very easily.
Old Feb 28, 2013 | 06:17 AM
bozwell's Avatar
Talking Re: Lt1 into Ls1 hole
thanks for the info.looks like its a 5.3 with nitrous.boz:
Old Feb 28, 2013 | 07:42 AM
bw_hunter's Avatar
If you're going to bore an iron block just grab an LQ4 6.0 out of a truck. They're dirt cheap and are torquey as hell. They have a lower compression ratio that the LS series engines allowing good results with a supercharger.
rideordie
Nov 5, 2019 04:52 PM
edman
Jan 22, 2015 02:45 PM
Jul 4, 2005 05:00 PM
