strange noise..
Old Dec 20, 2012 | 06:18 PM
mikemassi's Avatar
strange noise..
i have 94 lt1 a4. i recently did a CC503 cam in my car and ive been driving it for weeks untill one day i started my car and when i came back out to leave i heard a strange metal clanking noise coming from under the hood. the noise is not consistant with motor speed and when i rev the car up i cant really hear it at all. also when i took it around the block the car runs smooth and has no miss or and vibrations, but when i hit the brakes hard i loose oil pressure for a second. is it likely my pick up fell off inside the pan and could be hitting the crank?
Old Dec 20, 2012 | 06:56 PM
RamAir95TA's Avatar
Re: strange noise..
Definitely sounds like the pickup may have fallen off. Rap the bottom of the pan with a rubber mallet and see if you can hear it bouncing around. Or if you (or a friend) have a lighted borescope you could drain the oil and inspect through the fill plug.
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
KYWes
Aug 10, 2015 07:03 PM
