ltcc question
Old Nov 24, 2012 | 06:47 PM
1badasZ's Avatar
ltcc question
Do you still have to use the icm with the ltcc setup? Or does it eliminate that along with the coil? I'm going to try this setup and if it still won't run right then the hell with it I'll just part the car out. I've bout had enough. I would try the efi connection but my transmission ain't compatible with it
Old Nov 24, 2012 | 09:53 PM
slick1hunting's Avatar
Re: ltcc question
Doesnt use the icm. Be sure to hook the wiring correct or can fry the ltcc box.
Old Nov 25, 2012 | 09:35 PM
97WS6SCharged's Avatar
Re: ltcc question
The LTCC does away with both the coil and ICM. What transmission are you running that isn't compatible with the 411 ECM?
Old Nov 26, 2012 | 11:16 AM
ramair96ws6's Avatar
Re: ltcc question
LTCC is the best Mod you can do for your car period.. Use the thunderracing coil relocation kit and some moroso ultra 40 wires and it looks ****!
Old Nov 26, 2012 | 03:28 PM
1badasZ's Avatar
Re: ltcc question
I'm running the 4L60E, but it's an obd1. They said I'd have to have obd2 electronics
Old Nov 26, 2012 | 11:27 PM
Re: ltcc question
I actually forgot about the OBD1 autos being different. I've run 6 speeds for the last 12+ years. Unfortunately it's not just the electronics that are different. The pump, valve body and separator plate are all different as well.
Old Nov 27, 2012 | 06:16 AM
1badasZ's Avatar
Re: ltcc question
See, I never have the easy way out lol
DirtyDaveW
Mar 15, 2015 07:01 PM
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
