lt1 oil cooler delete
Old Nov 17, 2012 | 01:36 AM
94raiderz28's Avatar
hi im new to the forums and was had a question about oil cooler delete, so i have a 94 z28 lt1 and want to delete the oil cooler, is there any things i need to know before removing such as oil temps higher or anything that will hurt the engine? also i will be running castrol gtx titanium 5w30 full synthetic. any info will help thanks
Old Nov 17, 2012 | 02:13 AM
Compstall's Avatar
Re: lt1 oil cooler delete
Why would you take it off
Old Nov 17, 2012 | 08:22 AM
It's not going to hurt anything, especially if you use synthetic oil.
Old Nov 17, 2012 | 11:06 AM
I want to take it off because it doesnt sit right at the block and leaks like crazy even with new gasket and tightening it down and plus im planning on getting long tube headers and been reading you need to remove it for clearence
Old Nov 17, 2012 | 11:28 AM
And do i need to use a longer oil filter? If so do you guys have some part numbers for them?
Old Nov 17, 2012 | 01:48 PM
No, you don't need a longer filter. You can use one if you like, but if you are after more clearance, you might not want one.
Old Nov 17, 2012 | 02:05 PM
Ok... Thanx for the info
DirtyDaveW
Dec 1, 2016 05:37 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
97 RedSS
Jun 10, 2003 07:58 PM
