major bogging durring heavy acceleration
Old Jan 2, 2013 | 10:03 PM
94raiderz28's Avatar
I have a 94 z28 bone stock and just recently had a problem, when its cold it runs fine, but as soon as it warms up and try giving it full throttle it holds back and jerks as if it was bogging down... Any ideas what this can be?
Old Jan 2, 2013 | 11:16 PM
Locruid's Avatar
Re: major bogging durring heavy acceleration
Whens the last time you changed your Fuel Filter?
Old Jan 3, 2013 | 06:25 AM
bw_hunter's Avatar
I don't know why a fuel filter would be temperature sensitive...that's not likely.
Try running a scan to see if you have some codes....some don't set the check engine light.
It's quite possible that this is caused by the coolant temperature sensor in the water pump. A scan will tell you water the PCM thinks the temp is....if it thinks the engine is cold it enriches the fuel mixture until it warms up. This enriched mixture will make the engine run poorly.....
Old Jan 3, 2013 | 11:40 AM
Thanks ill try scanning soon as i can get a scanner... Any scannera that are good for a cheap price?
Old Jan 3, 2013 | 11:58 AM
Locruid's Avatar
I've had it happen twice. Not so much as just because it's warm, just happened to start bogging down about the time it got warm.
Old Jan 3, 2013 | 12:17 PM
bw_hunter's Avatar
Nothing really cheap out there. You can do it with a laptop and a cable using scannet software called Datamaster. There another one but it seems to be unavailable. Datamaster allows 20 scans for free then requires that you purchase the package...
Old Jan 3, 2013 | 04:25 PM
LowRyter's Avatar
autozone will scan your car for free
Old Jan 3, 2013 | 04:57 PM
Most of the auto parts stores seem to be limited to OBD-II scans. If you are going to own one of these cars, its essential that you have a scanning capability. The DataMaster software is very good for OBD-I applications. I review data logs for people all the time. There's a lot of info in a detailed scan log.
Just for the heck of it, check for a tear in the inlet elbow between the MAF sensor and the throttle body. Or possibly the bottom of the elbow is not fully on the throttle body.
Old Jan 3, 2013 | 05:20 PM
Locruid's Avatar
Heh I got in a fight with one near me cause I kept telling him its an OBDII Connector but OBD1 software.
Old Jan 3, 2013 | 10:29 PM
Fortunately the OP does not have that problem on his 94.
Old Jan 6, 2013 | 12:16 PM
i put a new engine coolant temp sensor and have had no problems for 2 days now.... hopefully it stays that way
Old Jan 6, 2013 | 12:26 PM
bw_hunter's Avatar
Good Luck!
Old Jan 12, 2013 | 12:11 AM
BubbaBexley's Avatar
Had the same problem. It was a warped intake manifold.
Old Jan 12, 2013 | 10:39 AM
RamAir95TA's Avatar
First I've ever heard of this...ever.
Old Jan 12, 2013 | 11:01 AM
Ditto.... 14 years here and never saw that cited in a problem on this forum. Definitely not a common problem.
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
Sep 11, 2015 09:44 AM
