acceptable compression numbers on a test
Old Dec 19, 2012 | 08:34 PM
Cbystrack's Avatar
i have a problem and that is cyl #2 is running insanely lean
checked the injector today and its clean, it sprays as it should.
Did a compression test on the cylinder and i saw 125psi..... from what im reading lt1s are usually quite higher????
i have not checked the other cylinders yet for compression nor have a pulled the valve cover off yet to check rockers/springs... there is no valvetrain noise at all.... Anyone have any ideas for me to try?
Old Dec 19, 2012 | 09:03 PM
bw_hunter's Avatar
Re: acceptable compression numbers on a test
I guess typical would be about 175psi. A couple of questions:
1) do you plan to test the other cylinders? You should see no more than a 10% difference between them.
2) did you run the compression test with the throttle wide open? A closed throttle will give a low value.
3) have you considered doing a leakdown test done? It might help figure where the issue is....
Old Dec 19, 2012 | 09:11 PM
Cbystrack's Avatar
no i did it just by pulling coil wire and turning it over, i will test others in the am with the throtle wide open. only thing im possibly thinking is that maybe two wires are crossed.... im thinking it could be 2 and 8 seeing there right next to eachother on the opti cap.... im trying my damn'dist to get this bad boy fixed.
Old Dec 20, 2012 | 08:18 AM
white97T/A's Avatar
How can you tell the #2 is the only cylinder running lean?
Old Dec 20, 2012 | 08:51 AM
Cbystrack's Avatar
changed plugs and cyl number 2 came out white
F'n1996Z28SS
Aug 23, 2023 11:19 PM
naaz90
Jul 27, 2002 08:22 AM
