Low coolant light ?
Old Nov 27, 2012 | 04:41 PM
Erik Castaneda's Avatar
Low coolant light ?
My 1997 camaro z28 the low coolant light
Has came on so I checked my coolant to see if it needs more
. But the coolant level is okay. I'm wondering what is that making it come on if the coolant is okay.
Old Nov 27, 2012 | 05:04 PM
bw_hunter's Avatar
Re: Low coolant light ?
This is a common fault on our cars. If the level is fine, the sensor is the problem. You can remove the sensor and clean it or you can just replace it. Or, if you don't mind checking your own fluid level, you can just unplug it and leave it unplugged....it won't hurt anything (unless you let the water level drop)
Old Nov 27, 2012 | 06:53 PM
bowtiedad_z28's Avatar
^^^^^ What he said.
Old Nov 28, 2012 | 08:05 AM
MeanLT1GreenZ28's Avatar
Check out:
4th Gen LT1 F-body Tech Articles
It explains how to deal with the sensor.
http://shbox.com/1/low_coolant2.jpg
It explains how to remove it.
4th Gen LT1 F-Body Tech Aids
It is a great resource for all 4th gen Camaros.
Hope this helps.
Old Nov 28, 2012 | 09:28 AM
Thank you this helps a lot
Old Nov 28, 2012 | 10:22 AM
You're welcome. I just got mine a few days ago and it has the same problem. Been waiting for a warm day to try to take off and clean the sensor. Hopefully I can get to it this weekend.
Old Nov 28, 2012 | 01:32 PM
bw_hunter's Avatar
Just so you know...cleaning rarely, if ever, solves the problem...
Old Nov 28, 2012 | 02:35 PM
Where are you checking the coolant level? Hopefully not in the reservoir.
I've seen one of the sensors disected by an electrical engineer and it showed that the coolant had leaked into the electronics, destroying the circuit board. Not repairable if that's the case.
Old Nov 29, 2012 | 05:51 PM
ToocoolZ28's Avatar
I replaced mine and it started coming back on a few months later, I just unplugged it and no more problem. Just make sure to check the level once in a while
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
