Help... Car lagging at acceleration no vaccum leaks new intake elbow
Old Dec 19, 2012 | 11:44 AM
mjones60's Avatar
I found out that my car had two spark plug wires that were burnt by the passenger side header. I changed the wires and the plugs and its still holding back power. It runs good at idle but when i push the gas it seems as if it still has a misfire. There are no check engine lights present. I hope it isnt the optispark distributor that i have to change. I also need to pull the wire to see if the wires are sparking the plug because the connector boot on the optispark is hard to connect on that passenger side. I also have the Bosch Platinum fusion Spark plugs in there. People say those plugs causes misfires sometime.
Old Dec 21, 2012 | 09:42 AM
Chet1185's Avatar
I have run Bosch with no problems. Does the car backfire or die when warmed up? That's how mine was every time the opti failed.
I have found it easier to have a spare spark plug to just attach to the wires I pulled to see if it had spark.
Posted from Camaroz28.com App for Android
Old Dec 21, 2012 | 11:57 AM
Re: Help... Car lagging at acceleration no vaccum leaks new intake elbow
Since this is a duplicate of this thread:
https://www.camaroz28.com/forums/lt1...les-ok-870809/
.... I'll close this one. In general, it's not a good idea to post the same problem in two different threads.
USAirman93
Nov 24, 2014 03:37 PM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
