97 z28 horsepower
Old Jan 14, 2013 | 08:38 PM
johnboyz28's Avatar
97 z28 horsepower
need some help on some easy things to do to get some more horse i have cold air new plugs and wires if anyone knows a easy way to get extra horse on a short budget id appreciate it
Posted from Camaroz28.com App for Android
Old Jan 14, 2013 | 08:48 PM
RamAir95TA's Avatar
Re: 97 z28 horsepower
Headers and a full catback exhaust should get you about 20whp for around $500-700. That's the next logical step.
Old Jan 14, 2013 | 09:22 PM
johnboyz28's Avatar
is there any way to clean stock intake without removing it
Old Jan 15, 2013 | 10:49 AM
Lilatlboy6969's Avatar
you can seafoam ur car but there's no real good way to clean it without taking it off
Old Jan 15, 2013 | 03:03 PM
D'Z28's Avatar
water bypass on throttle body u already have cia then what ram air said is a good start maybe some gears
Old Jan 15, 2013 | 03:32 PM
johnboyz28's Avatar
already been seafoamed. any suggestion on some decent gears i have 6 spped T56
Old Jan 15, 2013 | 03:41 PM
4.10's work great with the T56's deep O/D gears.
Does the intake have heavy oil deposits behind the throttle body? That is sometimes the sign of a plugged PCV valve or excessive crankcase blowby. Pull the top cover off the throttle body and see if there's a puddle of oil.
Use carb cleaner. Just don't spray the carb cleaner on the throttle body. It's harsh and can remove the anti-coking coating on the blades.
Old Jan 15, 2013 | 06:26 PM
parkers Z28's Avatar
A full exhaust will give the car a great sound!! With the right muffler it may only add 20hp but it will sound like it has much more gives it that hot rod sound. If you can't do a full exhaust change the muffler you won't get the 20hp but it will sound good .
If you wanted to clean the out side of the intake for appearance scrub it with a wire brush the intake will look like its new!!! take your time being sure not to cut any wires or disconnect anything !!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 29, 2015 07:10 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
NewsBot
Dec 28, 2014 06:20 PM
