Head Bolt question...
Old Jan 28, 2013 | 05:54 PM
94arcticwhiteM6's Avatar
Are the head bolts the same for an LT1 and gen 1 small block? There is a complete head bolt kit from GM performance parts that I really liked when I built a gen 1, and wanted to see if I could use it on an LT1.
Old Jan 28, 2013 | 06:14 PM
Kevin Blown 95 TA's Avatar
Re: Head Bolt question...
Yeah they are the same in most respects. Some of the later LT1s, 96 & 97 I think, had TTY bolts, but you could still replace them with common SBC bolts.
Old Jan 28, 2013 | 06:16 PM
RamAir95TA's Avatar
I like the ARP 134-3601s, personally.
Old Jan 28, 2013 | 10:38 PM
As long as they have washers...
Old Jan 30, 2013 | 08:05 PM
Dtimekw's Avatar
Keep in mind that EARLY Gen 1 head bolt sets WERE different. The inside outer bolts (2) are not the same length as the common Gen 1. The heads are actually machined differently thus the need for different bolt lengths.
Old Jan 30, 2013 | 11:06 PM
MachinistOne's Avatar
This.
You must use head bolt washers with standard hardware, or use the flange head bolts such as felpro or ARP sell.
Old Feb 5, 2013 | 10:01 PM
Vader's Avatar
The 1994 LT1 has head bolts that look like the Gen 1 bolts, but have a captive washer, needed for the aluminum head. But the LT1 bolts even in that year are TTY and one use only. I would think the 93's are the same, but I haven't had one of them apart.
Old Jun 11, 2013 | 03:08 AM
will.b.brown's Avatar
my 94s were most definitely NOT tty. they changed to stretchy bolts in 95 or 96. used to know for sure but i forgot now.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
