vacuum question
Old Oct 26, 2012 | 11:31 AM
hoosierkc89's Avatar
vacuum question
I would like to run some seafoam through the engine, and the bottle says to run it through the vacuum system. Which line do i use? I know it is probably a dumb question but i just want to make sure i do it right. 1995 z28 LT1
Old Oct 26, 2012 | 02:10 PM
timnfxr's Avatar
Re: vacuum question
Pull the vacuum line off the power brake booster. Put a small funnel right into the hose, making pouring easier.
Old Oct 26, 2012 | 04:03 PM
parkers Z28's Avatar
Re: vacuum question
You can also buy the seafoam in a spray can . just slip the tube that comes on the can into the spray nozzle then slide it into the air intake boot give the car a little gas to keep the car from stalling and spray it
lt1matt
Mar 21, 2015 07:35 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
madwolf
Aug 2, 2001 08:32 AM
