6.125 rods in a 355?
Old Oct 27, 2012 | 11:25 PM
1badasZ's Avatar
Rebuilding the engine and would like opinions or pros and cons on using 6.125 I-beams and pistons to match with the stock crank. If it's a bad idea please lemme know. Was just wondering if the lil extra stroke would be beneficial
Old Oct 28, 2012 | 07:35 AM
bw_hunter's Avatar
Re: 6.125 rods in a 355?
Rod length does not change the stroke. The crank throw length determines that. Longer rods simply put the piston farther from the crank.
Longer rods have advantages and disadvantages. I think the engineers can well explain them. The most obvious downside is where they force the piston pin to be in the piston. Longer rods force the pins toward the piston crown, crowding the area where the rings live. Jamming all this towards the piston crown can lead to the pistons rocking in the bore....
All that said, I think the best compromise is to use a 5.85" rod which changes the thrust force angle but leaves enough room for the ring pack....
Old Oct 28, 2012 | 09:56 AM
1badasZ's Avatar
Ok thanks, was just curious about all of it n didn't want to make a mistake and be pulling it right back out anytime soon. Also I plan on spraying 150-200 if that makes any difference as far as where the pin sits on the piston.
Old Oct 28, 2012 | 10:42 AM
If your running nitrous, you want nitrous pistons. They will have a heavier crown. They will have the ring pack dropped down to get the top ring further from the heat, and strengthen the ring land. Even on my 381 with 5.85" rods, the pin is in the oil ring and required ring rails. With the stock stroke, you might even want to stick with stock rod length.
Old Oct 28, 2012 | 12:03 PM
1badasZ's Avatar
Ok thanks Fred, I'll have to check into some nitrous pistons. Glad to know there's a difference. I thought long as they were forged they were ok. I was looking at the mahle power pack.
Old Oct 28, 2012 | 01:52 PM
I'm very conservative, and listened carefully to the guys that built the engine. They had some incredible LT1 builds to their credit, and extensive nitrous experience.
Old Oct 28, 2012 | 04:00 PM
1badasZ's Avatar
Only "nitrous" pistons I can find are domes and the compression would be thru the roof with 54cc heads. Looked at je and diamond n both were domes
Old Oct 28, 2012 | 04:17 PM
bw_hunter's Avatar
Nitrous loves high compression...which helps explain the CR of the aftermarket pistons....
Old Oct 28, 2012 | 07:38 PM
MachinistOne's Avatar
How much nitrous do you plan on using?
Old Oct 28, 2012 | 10:02 PM
1badasZ's Avatar
No more then a 300 shot and that's if I go with the direct port. If money runs out n I just go with a plate kit no more then 200
Old Oct 29, 2012 | 12:20 AM
No reason to not run a 6.0" rod with a 1.250" comp height piston. A standard 2618 piston will handle a 300 shot no problem as long as the tune is right, doesn't matter what piston you have if the tune is bad.
JE Auto piston #130974
That's a standard series -14.5cc inverted dome piston that should put you at 10.5 with a 9.0" deck and LT1 chamber. If you'll run race gas or good fuel, you can easily go higher if you can find a 2618 piston with an 11cc dish.
Call Total Seal and have Keith Jones set you up with the right rings, an AP steel set might be right, #CSL3690 with a Napier 2nd ring subbed in would be nice.
On the original question, no, I would not use a 6.125" rod with a 9.0" block unless it's a no nitrous road race application where piston weight is important for the rpms being run.
Old Oct 29, 2012 | 06:01 PM
1badasZ's Avatar
When you say good fuel are you referring to race fuel or 93 pump gas? And the nitrous kit will have a stand alone fuel system with race gas. Don't want to risk leaning put the intank pump.
Old Oct 30, 2012 | 01:28 AM
You could go past 11:1 if running 93
Old Oct 30, 2012 | 07:13 PM
1badasZ's Avatar
That's all I run in it is 93. Thought I had to cause of the tune and extra compression form the le2's and impala head gaskets
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
