Torque Converter Shims
Old Jul 6, 2003 | 10:13 AM
ChevyCamZ28's Avatar
Guys,
I have a little too much of a gap in between my torque converter and my flexplate. The gap is at a 1/4" and I would like it to be around 3/16"
Does anyone know where you can get the shims that will go inbetween the torque converter and the flexplate? I was thinking about maybe just using body shims? I'm not sure if they make shims specifically for this application...
Thanks for any help,
Mike
Old Jul 6, 2003 | 11:29 AM
FastZinTennessee's Avatar
I have never heard of anyone having to use shims. Anyhow, if I was looking for something to space it, I'd just go to home depot or lowes or something and get some washers.
John
Old Jul 6, 2003 | 11:31 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
why do you wanna do that?? whats wrong with the clearence?
Old Jul 8, 2003 | 04:36 AM
Pro Built Automatics's Avatar
Ideal clearance is .090 - .125, If more you will need to get "machined" washers. You will need 3 washers exactly the same in thickness to achieve this, no more than .001 variation among them. The purpose of this is to get "maximum" tooth (rotor) contact on the torque converter hub for distributing the load. This will give the best chance at a long rotor life, less wear, and less metal in the fluid. Less than the above stated clearance can cause front pump problems (transmission failure), or you can "wipe out" the thrust bearing in the motor. Either is disasterous.
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
