Low water light?
Old Jul 3, 2003 | 10:55 PM
silverz28's Avatar
Question Low water light?
I've had this low water light on my dash for about a year and a half now, but my radiator is not low. What gives? Is it the sensor?
Old Jul 3, 2003 | 11:34 PM
slashz28's Avatar
could be the sensor on the rad itself, maybe the one on the side of the (drivers side) head. hth
Old Jul 3, 2003 | 11:40 PM
DelSoto's Avatar
I don't know if this is good advice or not but the way I see it, there is a temp guage so the dummy light serves ME no big purpose. I had this problem. Bad sensor. I replaced it and it happened again so I just unplugged it......no more light!! A heed of warning tho....I am very good at maintenance and check all fluids pretty rugularly. Without this sensor......well......you can guess what may happen.
Old Jul 3, 2003 | 11:42 PM
DelSoto's Avatar
BTW, it was on the side of the radiator cap (passenger side) a couple inches from the top.
Old Jul 4, 2003 | 09:44 PM
silverz28's Avatar
Thanks, you wouldn't happen to know the part number to that sensor would you?
Old Jul 4, 2003 | 10:32 PM
DelSoto's Avatar
They have 2 part #s:
2 way conn is AC-DELCO #10096163
8 way conn is AC-DELCO #12135027
mine was the 2 way connector model but I have a 94. Not sure what a 96 sports. I read an article that stated that the 2000 up Camaro did away with the low coolant sensor.
Chad
Magenta_Hearts
Mar 29, 2017 08:54 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
pologreen97z
Dec 2, 2014 10:42 AM
