What headgaskets and injectors w/ new heads/cam ?
Old Jul 4, 2003 | 06:55 PM
pu12en12g's Avatar
Hey guys,
Long story short.. I blew a headgasket and now will be replacing wires, plugs, heads, cam, etc... not sure which cam to go with yet, probably a 306 or 305 ? Probably Lloyd Elliot or TPIS heads..
What are the best injectors I can have installed when I am having my heads / cam replaced ? Is this a good time to replace injectors ?
Also, should I replace the headgasket with the Impala headgasket or not ?
What are some other things I can upgrade while the heads are off etc.. etc..
Old Jul 5, 2003 | 10:55 AM
pu12en12g's Avatar
Well... is anyone running more than 36# injectors ?
Old Jul 5, 2003 | 11:11 AM
DirtyDaveW's Avatar
I've been using the Impalla shim head gasket (.029 compressed height versus .049 stock head gasket compressed height) since my rebuild in Dec 1999. No problems! Bumps up the compression ratio a bit of course. What kind of duty cycles have you been seeing on your scan/log runs? If you're above 85% duty cycle at WOT then, yes, go up on your poundage. Otherwise, why bother?
Old Jul 5, 2003 | 11:15 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
I would use the propper gasket to attain the compression ratio you desire.
How much were the heads milled? Do a search on dynamic compression in advanced tech and take it from there.
Injectors- same deal. bigger isn't better. You should be fine with 24# injectors and an adjustable fuel pressure regulator. I'd go with 30# and AFPR just incase you go bigger later.
Old Jul 5, 2003 | 11:17 AM
DirtyDaveW's Avatar
"Other mods while heads are off"
CSI electric water pump
Old Jul 5, 2003 | 12:52 PM
96z's Avatar
96z
Do what trey said regarding the CR.
I would get 30's to be safe. Your better off taking away some injector than pushing one to work.
Old Jul 7, 2003 | 01:00 PM
pu12en12g's Avatar
So I am around 100,000 miles, is this a good time to replace the injectors or not.. ?
Also, where is the best place to get the 30# injectors ?
Jegs ?
Old Jul 7, 2003 | 01:03 PM
DirtyDaveW's Avatar
cheapest way for new ones is to pick up a Fast Fords/Muscle Mustangs magazine and flip thru the online vendors. I've seen SVO 24# and 30# in there for as little as $189 a set before. More typically, you can find them from time to time for $209.
I bought mine from Tommy Vaughn Ford here in Houston for $209 and he's an advertiser in FF/MM.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
blaze309
Sep 8, 2015 05:27 PM
