HELP! T56 still 1/2" away from bellhousing
Old Jul 4, 2003 | 04:49 PM
PatriotTA's Avatar
Exclamation HELP! T56 still 1/2" away from bellhousing
I am finishing up a clutch swap and I have the trans lined up perfectly with the bellhousing. Everything looks great, but it just won't go in that final 1/2" or so. Any tips to help it go in? Two bolts can be threaded in, and they are on opposite sides.
Old Jul 4, 2003 | 05:02 PM
Ryan94ZA4's Avatar
Do you have the clutch fork pulled out? If you don't, the trans won't fully seat.
Ryan
Old Jul 4, 2003 | 05:19 PM
whitehooptie's Avatar
Did you install a new pilot bushing? Are you sure the clutch is aligned properly? If there is a new pilot busgin in there, it will be a little difficult to get it in there.
Old Jul 4, 2003 | 06:14 PM
PatriotTA's Avatar
I am sure that everything is aligned properly, and I did install a new pilot bushing. I attached the fork to the bearing, should I remove it, and attach it later? I just did it now because it was easy to see that it was on correctly. Any other ideas?
Bxlt1
Sep 29, 2015 03:18 PM
Henson071
Sep 18, 2015 04:01 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
1slow93z28
Sep 1, 2015 06:22 PM
