axle swap
Old Jul 4, 2003 | 08:49 AM
justahoe's Avatar
axle swap
Has anyone done a axle swap on a late model F body. I was thinking this might be a cheaper route then a 12 bolt or 9 in. At least for a little while.
Old Jul 4, 2003 | 01:24 PM
Not sure I understand... you have the "latest" model F-Body, unless you are thinking of the rear out of a 98-2002 LS1. But its the same weak 10-bolt.
The 3rd Gen's had the same 10-bolt rear, except it is 3" narrower and has different brake brackets, so that wouldn't be an upgrade. There are some 3rd Gens with Australian made "9-bolts" that might be slightly better, but same problem with width, brakes.
SLP had some Dana rears made for some of the 3rd Gen Firehawks, so you might be able to find one of those, but they are pretty rare.
Old Jul 6, 2003 | 04:49 PM
justahoe's Avatar
I meant change the axles to like a 31 spline or 33 spline.
2QUIK6
Sep 17, 2016 02:31 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gtstriker86
Aug 26, 2015 10:56 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
