OEM Coil or aftermarket ign coil?
Old Jul 4, 2003 | 05:29 PM
Robert95z's Avatar
I have a high rpm miss right before it shifts, probably around 5400rpm.
I'm going to go ahead and change the coil, should i get an aftermarket one or just an OEM one?
Old Jul 4, 2003 | 05:34 PM
Ryan94ZA4's Avatar
I"d honestly go OEM as the aftermarket ones available don't have a real good track record for reliability.
Ryan
Old Jul 4, 2003 | 06:21 PM
CamaroBoy96Z28's Avatar
I'll be replacing my coil soon and I'm going OEM. Some guys have posted problems with aftermarket coils. There is no benefit from a more powerful coil or at least any proof. OEM is more than adequate.
Old Jul 4, 2003 | 07:01 PM
n2ceptor's Avatar
This question has been asked in the past acouple of times, try the search function and all will be reveiled...
Old Jul 4, 2003 | 08:17 PM
94GrayV6's Avatar
I have a Holley one on mine and it works fine. BTW, are you sure the opti isn't causing your miss?
Old Jul 4, 2003 | 08:43 PM
Fatdog's Avatar
Cool
Might try a new COIL WIRE first.First signs of a high rpm miss is the coil wire.Stock coil here.My02
Old Jul 4, 2003 | 08:47 PM
SDAKOVIC's Avatar
i had the same thing going on, then i got a custom chip from madz28.com and the problem is gone.
Old Jul 4, 2003 | 09:02 PM
RCF925's Avatar
I doubt the coil is your high rpm miss, I f your gonna replace it get an OEM, If your running stock valve train you could be getting some valve float ( Weak Springs). I had the same problem for quite a while and replaced MSD Box,Opti, Plugs,wires,coil,ignition module etc. Turned out to be valve float due to weak stock springs.
canbaufo
May 5, 2015 03:43 PM
heavenly_six
Dec 10, 2014 12:23 AM
Perry93TransAm
Aug 20, 2002 11:23 PM
