throttle body blades???
Old Jul 3, 2003 | 05:11 PM
VINCELEE123's Avatar
where can i find a 52,54, or 58mm blade?
thanks vince
Old Jul 3, 2003 | 05:42 PM
snorkelface's Avatar
I've never heard of anyone just selling the blades. You're probably going to have to purchase a larger throttle body. I believe the stock ones can be hogged out to 52mm.
Old Jul 3, 2003 | 10:07 PM
Kinsler Fuel Injection in Troy Michigan (248-362-1145) can make you any combination you need in terms of:
-diameter
-bolt hole spacing
-material (2024 aluminum, 304 stainless)
-thickness ( .062", .071", .091")
-"closed" angle (std is 14deg)
-leading and trailing edge taper
Old Jul 4, 2003 | 12:24 AM
limige's Avatar
injuneer, you are the man! your so helpful and full of knowledge, thanks for the tip.
that's the biggest holdup for me hogging out mine. it's no big deal for me to bore out the holes and polish it up but those blades are elipses if i'm not mistaken, getting the correct size i think would prove to be a pain.
thanks again!
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
