Best Performance Non-lowering Spings
Old Jul 4, 2003 | 01:35 AM
pennys58's Avatar
Just as the title states...which ones are the most cost effective? I really just want some for better handling and launching...plus mine are poping like pop corn.
JOHN
Old Jul 4, 2003 | 07:00 PM
pennys58's Avatar
nadda??
Old Jul 4, 2003 | 07:02 PM
Cmr0z28's Avatar
ummmm for launching, eibach drag launch springs (they come with an air bag in the passenger side spring so you dont leave the line sideways) seem to be pretty good, not sure how they handle though. they also raise the rear of the car about 1/2 an inch
Old Jul 4, 2003 | 07:37 PM
pennys58's Avatar
Those look pretty good. Do you think I can do the low rider effect and bounce up and down the street? There isn't much info on them, but it says they have soft front springs, so I guess that would mean cornering would be adversely affected. Too bad they don't make adjustable springs for stiffness and softness. I don't autocross or anything like that, but I do drive it everyday and when it comes to handling, I need it to be able to handle well and provide a nice smooth ride and launch accordingly...I guess you cant have the best of both worlds though My buddies 00 vette handles awesome...I wonder if you could use a vette set up? I know they are wider and stuff, but could it be done? And if so, will it make a difference?
JOHN
Old Jul 4, 2003 | 08:59 PM
mike445's Avatar
From: Wasaga Beach, ON (formerly Ft. Lauderdale,FL)
I was told the 1LE springs are the best without lowering the car. I just ordered my set and have to pick them up on Monday. They are firm!!!
Mike
Old Jul 4, 2003 | 09:31 PM
Cmr0z28's Avatar
are you sure they are 1LE springs? I can't find them on slponline.com
where did you get them and how much?
Old Jul 4, 2003 | 09:59 PM
93formula's Avatar
1LE springs all the way if you dont want to lower it!
Old Jul 4, 2003 | 10:18 PM
mike445's Avatar
When I pick up my order on Monday I'll give you the part numbers. You can get them directly from any GM parts counters. The part numbers have all changed from what they were back a few years ago. It wasn't easy finding them.
Mike
Old Jul 4, 2003 | 11:58 PM
magius231's Avatar
if you get the entire HAL shock/spring system you can set it up to look like whatever you want and be as stiff as you want (fully adjustable). problem is the set is about $700
Old Jul 5, 2003 | 01:21 AM
96LT14u2Nv's Avatar
for launch i would recommend used 98 and up V6 camaro shocks/struts/springs. these things give sooo much it is crazy. but they suck for cornering.
Old Jul 5, 2003 | 03:53 PM
pennys58's Avatar
I would like to buy the Hal shock/spring combo. 700 really isn't that bad, considering you pay almost 400 for some kyb agx's and then another 200+ for some springs. So, you can adjust the ride height, with softness and firmness...or just the rate of the shock? Where can you find that Hal Combo. Also, how much are the 1LE springs?
JOHN
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
