Brents headlight fix
Old Jul 4, 2003 | 01:56 PM
Zack's Avatar
what tools/equipment will i need to do the job right?
Old Jul 4, 2003 | 02:54 PM
fbird95's Avatar
All you need is a socket wrench to take the arm off the motor. If i recall correctly its a 10 mm. then rotate the gear 180 degrees and reattach the arm. Its only a temporary fix, after about a month it only started grinding again.
Old Jul 4, 2003 | 03:59 PM
moparman's Avatar
It will work until the other side wears out. How long is that? Depends on how often you raise and lower the lights.
Old Jul 4, 2003 | 06:06 PM
Zack's Avatar
son of a bitch! now I have thenoise when the light goes up, but no noise when it goes down...
Old Jul 6, 2003 | 04:31 PM
fbird95's Avatar
You may have to take the gear out of the motor housing to find the good part of the gear. In my car, before i just got a new motor, 180 degrees didnt do it. I found the good part of the gear then sealed the housing back up, and all was good for another month and a half.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 17, 2015 09:50 AM
FredM
Aug 14, 2015 01:49 PM
Henson071
Aug 4, 2015 09:32 AM
