Longer length valves will result in what?
Old Jul 6, 2003 | 12:04 AM
Highlander's Avatar
I figure that with longer length valves.. say 0.200" more it will result in bigger install height springs.. Am I correct?
Another thing is that I will need to change the length of the pushrod??
What is the advantage of running a longer valve?
Old Jul 6, 2003 | 01:04 AM
Highlander's Avatar
I meant longer length not bigger diameter...
Old Jul 6, 2003 | 01:08 AM
Camaro_Maniac63's Avatar
Oops, I am sorry man. I guess it is time to go to bed now
Old Jul 6, 2003 | 01:09 AM
Highlander's Avatar
No prob man, thanks anyways.. What I am looking to know is how the geometry changes in the valvetrain?? I mean.. I would need to get shims, or shorter pushrods???
Old Jul 6, 2003 | 01:18 AM
Mindgame's Avatar
No advantage, it's just done out of necessity. Maybe the head is a high port type head (taller casting), or maybe the spring requirements are such that a large diameter wire will not allow for the correct coil bind clearance. Then you go to a longer valve or cut the spring pocket deeper.
Just necessity at times. But you're adding weight on the critical side of the valvetrain, so it's not advantageous.
-Mindgame
Old Jul 6, 2003 | 01:27 AM
Highlander's Avatar
What about titanium valves?
Old Jul 6, 2003 | 01:32 AM
Mindgame's Avatar
Question
What about titanium valves do you want to know?
-Mindgame
Old Jul 6, 2003 | 01:36 AM
Highlander's Avatar
If I were to get ones cheap... Are they worth it?? I have 2.02 and I want to step up to 2.05 or maybe 2.08 and 1.65 on the exhaust?? This is with AFR 190cc heads.
Old Jul 6, 2003 | 01:41 AM
Mindgame's Avatar
Not worth it.
You'd be 1000³ times better off spending the money on your cylinder heads. No gains in going Ti for a street motor that'll never see over 8k rpm.
-Mindgame
Old Jul 6, 2003 | 01:43 AM
Highlander's Avatar
But what about the 2.08 valves on the intake and 1.65 exhaust?
What about manley/ferrea valves? Worth it?? and if the set costs 200 bucks on the ti valves.. still not worth it? I am still learning. .that is why I ask, but one thing is very curious.. if you spend on ti retainers to lower weight why not valves?
Old Jul 6, 2003 | 01:56 AM
Mindgame's Avatar
Because you are talking no bang for the buck.
Titanium retainers are anywhere from $60-150. They reduce some weight on the critical side of the valvetrain and the valve has less effective mass.
Same goes for ti valves but look at the cost.... ~$80 per valve. Question is, is there a valvetrain problem that warrants a titanium valve???? Not at the revs seen on a street engine. The springs should be able to handle the job just fine at "street engine" revs. Once you really start spinning things that changes and there comes a point where the springs can't do their job properly. We're talking race engines here.
A 2.08/1.6 is just fine, although you will want to talk to a good porter. He will tell you if that's a good valve combination for the head or if you should consider something smaller. A 1.65 is most likely a waste... spend the money to have the exhaust port worked for your engine demands.
-Mindgame
Old Jul 6, 2003 | 02:10 AM
Highlander's Avatar
I dont have a head porter right now.. my heads where ported and there was a decent job made on them.. they are afr 190 heads...
I was thinking on putting better valves than the ones I have right now and was thinking of a bit bigger valves to aid the boost (lower it abit with more power as a result).
oldschool
Feb 9, 2016 09:21 PM
TitoPR221
May 26, 2015 12:20 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
