Bigges diameter valves that I can use on 190 LT1 AFR Heads?
Old Jul 5, 2003 | 11:36 PM
Highlander's Avatar
As the title says and I would like to know the length of the valves also...
Any advatages on running titanium valves over ferrea or manley? Thanks
Old Jul 6, 2003 | 12:11 AM
hvyss's Avatar
I run the 2.02/160 manley valves stock length for the LT1 in my AFR 190cc heads. As for lenght I don't know if you can go any longer than stock. As for size the biggest I have seen are 2.08/1.60 with very little clearance between the valves. You coudn't go any larger.
HVY SS
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
The Big Show
Aug 12, 2002 04:50 PM
Highlander
Aug 9, 2002 02:30 AM
