Possible to swap keyless.........
Old Jul 4, 2003 | 03:27 AM
whitehooptie's Avatar
entry from a 94 and convert it to the 98 and up style? I am wondering because the TRW factory keyless entries on my 94 is a piece of garbage. It doesn't work right half of the time. I want the newer style FOBs, and all that.
Old Jul 4, 2003 | 07:00 AM
scoobysnax83's Avatar
I asked this question a while back and never got a definitive response. A lot of the responses stated that it was not possible due to different receivers and frequencies. Hopefully you'll get a positive response on this one.
Old Jul 4, 2003 | 03:24 PM
I don't want to use the 94-95 Key FOBS. I want to use the newer ones so the frequency idea won't apply!
Old Jul 4, 2003 | 04:05 PM
what do you mean it won't apply? I mean that the newer ones use a different frequency then the older ones therefore the remotes are not swappable. Unless you can swap the receivers as well. I think it would be best for you to go the aftermarket route. Get a clarion or viper or something. I guess...
Old Jul 4, 2003 | 05:04 PM
FastZinTennessee's Avatar
Well the easiest thing to would be to buy a viper alarm, or keyless only if you don't want the alarm.
However, if you really want the newer style keyless, here's what I'd do. Go to a junkyard, find out if they have a car there with keyless, and the fobs and that they are the year you want. Find that car in the lot, pull the passenger side kick panel and runner(all one piece). In the kick panel there will be a black rectangular box with a couple of harnesses attached. That is the keyless module. You might be able to unplug that from the donor car, and plug it into yours. It could be that easy. Or it could be not possible. Only one way to find out.
John
Old Jul 4, 2003 | 05:17 PM
nope. in the later models, the keyless and BCM are one unit. The keyless entry plugs in the 98 and up are 6 prong and the 94-95 are 8 prong a piece. I think I can cut and few wires and get omethign going on. When I do, I will post.
Old Jul 4, 2003 | 05:21 PM
Well in that case, **** that!!! I'd just get an after market.......
Old Jul 7, 2003 | 08:48 PM
Any other ideas?
Old Jul 7, 2003 | 09:03 PM
I'm sure that it can be done. But I don't know if its practical.... It would probably cost you way more to convert it over an aftermarket set-up. But you'd be a pioneer.... Good Luck on your endeavor
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
