Could I have bent a pushrod?
Old Jul 5, 2003 | 12:24 AM
12SCNDZ's Avatar
I just did my cam/head/headers/etc. swap. I adjusted the valves to 0 lash+ 1/8 turn when I first put everything together. The car started and ran, but it fell on it's face at high (5800) RPM's. It also had an erratic idle. I pulled the valve covers and ran the valves again with the engine running. I definately had them too tight. Could I have bent a pushrod? I'm using COMP Hi-Tech chromemoly pushrods. After the valve readjustment, It seems to run exceptionally well. Just wondering if anyone has bent one from doing this. Remember, the motor DID run, so they weren't that tight.
Frank
Old Jul 5, 2003 | 03:26 AM
whitehooptie's Avatar
It is hard to bend chromoly. It is possible that one was too tight. I have had the same problem myself. It was just that one stud was a little different in length and caused my valve adjustment to be incorrect.
13qtr
Oct 28, 2016 08:11 PM
HibachiZ28
Nov 6, 2015 12:53 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
94Form
Jul 17, 2015 10:56 PM
