Mufflex Y-pipe?
Old Jul 4, 2003 | 01:44 PM
speed76demon's Avatar
Mufflex Y-pipe?
Does the side with two parts go on the passenger side or the drivers side?? Also what modifications should i be prepared to do to my car and the pipe to make it work with my jet hot lt's and my hooker catback?
Old Jul 4, 2003 | 03:45 PM
what nobody has a mufflex?
Old Jul 4, 2003 | 03:50 PM
doodad's Avatar
Two parts on driver side and be prepared to grind the frame right at that point and at the crossmember. And inspect your jethots very carefully, mine had a bad weld on the air fitting and blew out the second day and required cutting the fitting off and fabbing a fitting. You will love the performance BTW.
Old Jul 4, 2003 | 11:11 PM
Zulater's Avatar
I had to grind down the trans. crossmember as well. Still hits a little over big bumps.
Old Jul 5, 2003 | 01:11 AM
trax's Avatar
With my hooker LT's I didn't have to grind anything, but the Jet-Hot's are a different animal I guess. My mufflex has the O2 bungs on it so I had to spend some time aligning the pipes so the driver-side bung didn't go too close to the tranny crossmember.
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
COOPS89IROC
3rd Gen / L98 Engine Tech
Jun 17, 2002 06:58 PM
