quick swaybar install question!
Old Jul 5, 2003 | 10:29 AM
mkent's Avatar
i just installed new bushings on my swaybars but i am unsure of how far to tighten down the nut. i thought it would just stop tightening when it was ready but it never stopped and the top bushing was beginning to look like a pancake! so how do you tell if it's tight enough or not?
also, is there anything you can put on the bushings to keep them from squeaking? i've heard of this being a common problem with energy suspension bushings and other poly bushings
Old Jul 5, 2003 | 11:37 AM
1msfyter's Avatar
Snug the nut down, then the bushing should compress out about 1/8" or a little less.
Old Jul 5, 2003 | 11:49 AM
flyinZ's Avatar
I don't know about ES, but when I bought my Prothane bushings, they came with there own grease to put on the bushings...I guess you could use any kind of grease, maybe a lithium(sp) based grease....
Old Jul 5, 2003 | 12:09 PM
Sounds like you are talking about tightening down the end link bushings.... not the bar bushing caps. ES recommends that you NOT lubricate the end link bushings.
Chiltons recommends 16ft-lb for the nuts on the endlinks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Wilson
Jul 21, 2002 05:08 PM
