What exactly is cam surge???
Old Jul 3, 2003 | 07:14 PM
InGodITrust's Avatar
Question What exactly is cam surge???
Sorry if this is a dumb question....but what exactly is cam surge?? What is going on in the engine??
Old Jul 3, 2003 | 10:34 PM
OldSStroker's Avatar
Not a dumb question at all. The answers might be interesting.
Old Jul 3, 2003 | 10:47 PM
bunker's Avatar
Basicly big overlap at low rpm causes low BEMP / combustion pressure & causes very uneven engine airflow at those speeds cuz air comes in & lots escapes past the exhaust valve, we call this Effective compression, unlike static compression like 10.4:1 which is a stock engine, effective/trapped compression is how much air acctually gets compressed factoring in components like the camshaft, if most of the air escapes past the exhaust valve then you don't have much compression, & you have low power down low, you also suck in some of the exhaust gases back into your combustion chamber, thats why you have a ratical behaviour, as the RPM's climb you start to benifit from overlap because you get to cool your combustion chamber & with more duration you suck in more air, with small overlap you also open the intake sooner & exhaust later & since the air is being sucked in so fast, it doesn't get to excape past the exhaust valve, well atleast most of it doesn't, so these events become a benifit at high RPM as apposed to low RPM since you suck more in & exhaust later.
But basicly thats what cam surge is down low, & to make sure you dont go (so why don't we go stock) I explained the benifits of big cams, you sacrifice down low power for up top
Old Jul 3, 2003 | 11:12 PM
turbo_Z's Avatar
i think i know why but its difficult to explain.. here goes.
an aftermarket cam has larger lobes which keep the valves open longer.. this in turn slows down the combustion process. it takes more time for the cam and crank to make a complete revolution. this is most evident in the lower RPMs b/c the combustion isnt fast enough to spin the crank to where its a fluid clean motion and instead gets all choppy which is naturally transfered to the rear wheels... you have cam surge.
Old Jul 4, 2003 | 12:20 AM
limige's Avatar
if that was so then why do you get cam surge on blower cams? they have like no overlap, but you still get surge.
i was under the impression that cam surge was just the area below the power band, which doesn't produce the power until you hit the power band. reason for this i think turbo z explained, airflow is blubbered up and doesn't smooth out until higher rpms. same idea as why bigger cams need higher idles.
Noenav
Mar 1, 2019 07:38 AM
AdsoYo
May 2, 2018 03:21 AM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
