Were to buy a 383 short block?
Old Jul 5, 2003 | 10:34 PM
GEES97TA's Avatar
Question Were to buy a 383 short block?
I wamt to purchase a 383 short block containing some decent pistions/rods/crank were would be the best place to buy this...
Also i need this set-up for a blower car i would like to lower the compression down some...thanks alot guys....
Old Jul 5, 2003 | 11:35 PM
DirtyDaveW's Avatar
Check with Scoggins-Dickey. They *used to* have a 383 shortblock with all the heavy duty innards AND you had a choice of normal compression ratio or dished for your blower requirements.
Old Jul 6, 2003 | 12:34 PM
jmzlt1's Avatar
What's up GEE, this is James, we met on the camaro firebird vs. mustang challenge, I have the red ta. I see your looking into getting a 383. How much did Cartek want for a 383 shortblock? Scoggin Dickey sells it for 4285, they only list for 10.8 or 11.8 comp ratios. I'm sure they can accomodate you with what you need if you give them a call. I know their assembly has lunati components. Also, you might want to give nu-tek motorsports, combination motorsports or baur racing engines a call. Baur racing and combo are our sponsers and you can see nutek at www.nu-tekmotorsports.com Hope this helps a bit, later.
Old Jul 6, 2003 | 12:40 PM
SunCoastTA's Avatar
I say just buy the kit. Here is the one I am going with ( http://www.excessivemotorsports.com/product.phtml?p=301 ) and total price using my block is going to be around $1,600. It comes with Nodular Steel 383 Crankshaft, Lightweight SIR 5140 Forged I-Beam Rods, JE/SRP Forged Aluminum Pistons, JE Hyfire Rings (file-fit), Clevlite Rod Bearings, Clevlite Main Bearings. Or for $600 more you can get the stage 2 kit.
Old Jul 6, 2003 | 12:41 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
www.cmotorsports.com
they kick *** with forced induction
Old Jul 6, 2003 | 12:58 PM
GEES97TA's Avatar
Hey guys,thanks alot for the some of the cool places i can look into..
Hi James you going to GM high tech day July 12th if so let me know ill probably be going down..They re-tuned car my car and did the new ignition system so it should be running better now i hope I just want to do a soild motor for plenty of supercharing miles nothing is wrong with my motor but i might as well change it before i blow this one up...
Old Jul 6, 2003 | 01:07 PM
jmzlt1's Avatar
Yeah, I'm going. I'm not sure if I'll run though. If it's 90 degrees, I probably won't run, we'll see. I'll see you down there, later.
Old Jul 6, 2003 | 02:06 PM
ramair96ws6's Avatar
Suncoast Ta Don't buy from excessive motorsports THEY ARE CROOKS!!!!!!!!
Look what they have done to some mustang folks!!!
http://www.corral.net/forums/showthread.php?threadid=115796
I have not bought from them but if even half of this thread is true I would not send them a dime!!! I would go with one of the sponsors of camaroz28.com combination motorsports is an awesome company to deal with.
D1SC383LT4
Jan 1, 2016 01:56 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Collector Car
Dec 17, 2014 01:12 PM
