rocker arm / valve problem ...
Old Jul 4, 2003 | 02:36 PM
Seanndogg's Avatar
I just had my heads milled which threw off the geometry of everything a little bit and I needed shorter pushrods. Well now as I set zero lash and plus 1/2 turn, the rockers start rubbing against the adjusters. It just doesn't seem right this time. Some are ok though. Should I just try and start it up and maybe get some oil pressure going or what ?
Old Jul 5, 2003 | 04:59 PM
Seanndogg's Avatar
ttt
Old Jul 5, 2003 | 08:15 PM
I don't understand "rockers rubbing on the adjusters".
If something does not seem right, I would not run it that way.
Old Jul 7, 2003 | 02:11 PM
Seanndogg's Avatar
It's hard to explain but it's running fine now, thanks anyway.
Old Jul 8, 2003 | 05:57 PM
arnie's Avatar
As a rule, mechanical problems don't just go away.
Old Jul 9, 2003 | 02:32 AM
Seanndogg's Avatar
I didn't start it untill I knew it was right. It is now right. thanks
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
newby
Jul 25, 2002 03:22 PM
Redbird
Jul 20, 2002 06:08 AM
