Knock count and PCM learning
Old Jul 6, 2003 | 12:54 AM
95Blackhawk's Avatar
Do our OBD I PCM's learn knock? I reprogrammed my PCM a few times with this phenomenon. After the reprogram, I datalog only to find that after a while, the PCM seems to pick up less count - and thus my KR is reduced. Yes my conditions are the same and this happens in a time frame of 20-30 min from when I reprogram.
My BLM's are good and I know my AFR is pretty consistent at 12.4:1 right now throughout the RPM range.
Is this something that is programmed into the PCM? Damn confusing as I chase false knock!
Ben
bunker
Jan 30, 2016 08:09 PM
pimpen1024
Aug 19, 2015 08:36 PM
canuck94z28
Aug 19, 2015 05:50 PM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
