Tranny Cooler
Old Jul 4, 2003 | 10:42 AM
TransAm9585's Avatar
Tranny Cooler
Iv looked through alot of the posts on the Tranny cooler install and at a bunch of install guieds but im still a little lost and getting contradicting line locations. Am i correct in stating that when planning to use the stock cooler and an aftermarket cooler that i only need to disconnect the returning line to the transmission and run the hose from that to the new cooler then run the second line from the new cooler to the factory line back tot he transmission. Any help would be apprciated thanks.
Old Jul 4, 2003 | 10:54 AM
TMDZ28's Avatar
yes. get under the car. i did not understand a thing until i got under the car....
Old Jul 4, 2003 | 11:01 AM
Kris93/95Z28's Avatar
It really is that simple, I did mine pretty much like all the write ups, but I took out my radiator since I was told not to run the clips through the radiator, and also since I might need to pull the radiator some time, thi sjust made more sense for me.
Old Jul 4, 2003 | 11:03 AM
BTW: If you need pics just ask
Old Jul 4, 2003 | 11:25 AM
I appriciate all the help guys, and iv got pictures the only thing is alot of them contradict each other. Im gonna crawl under the car and take a look at this today. If you want to send some pics by all means do. Ill see if they dont clear thigns up
Old Jul 4, 2003 | 12:39 PM
ttt
ttt
Old Jul 4, 2003 | 01:01 PM
TMDZ28's Avatar
the main important thing to look at is:
1. you have to find the line that goes from tranny TO the radiator
2. you have to find the line that goes FROM the radiator to tranny
3. disconnect both lines
4. connect line no.1 to the tranny cooler, and the no.2 line to the tranny cooler.
5. have a smoke or a beer, cause you are done
hope that helps.
so it works like this
tranny fluid -->radiator -->tranny cooler --> back to tranny
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
