Milling heads and compression
Old Jul 6, 2003 | 12:03 PM
DjArcadian's Avatar
I will be plulling my heads shortly to fix the thread in a header bolt hole shortly. Also doing the rear intake leak fix. I am considering getting the head milled and using an Impalla SS gasket. What will this do to my compression and what type of problem should I look out for. Will this create any type of valve clearance issues?
Old Jul 6, 2003 | 12:29 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
you will only be miling a tiney bit off, nothing to worry about with piston to valve clearance
Just make sure you dont take too much off- Personaly I like using pump gas
Old Jul 6, 2003 | 12:34 PM
gb95zconv's Avatar
Shouldnt be a problem....you want even lose a whole cc per chamber so compression gain will be about .25-.5 depending on the gasket you were using before.
Im going to be running the .029 gasket as well....just looking at it make me a bit nerves about using it compared to the felpro .039 that I was using. Im breaking one of my rules here by not sticking with what I know works for the sake of .25 gain in compression Sorry ...just felt the need to add that.
Old Jul 6, 2003 | 12:38 PM
DjArcadian's Avatar
Will there be any performance gains?
Old Jul 6, 2003 | 12:41 PM
gb95zconv's Avatar
not much...but a dyno would show a hp increase....I forget the rule of thumb on what to expect. I added to my previous reply also....take a look at it.
Old Jul 6, 2003 | 12:44 PM
treyZ28's Avatar
not really, not on a stock motor.
the main reason people increase compression here is due to a bigger cam that bleeds off more compression. going from 10.5 to 10.8 isn't going to yeild a whole lot.
Victor Lamb
Aug 26, 2017 02:52 PM
pimpss96
Feb 12, 2015 01:28 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
