Quick Evap ??
Old Sep 18, 2003 | 05:20 PM
Z28Boss's Avatar
Exclamation Quick Evap ??
Please look at the EVAP diagram at the following link
http://csce.uark.edu/~jgbertr/rb/1996_evap.jpg
I have a question about the diagram, on my car the number 5 elbow is all cracked and worn. Is this a vacuum hose?? I have a rough idle and I noticed that this is in pretty bad shape. Even if it isnt a vacuum hose, what does it do and should I get that fixed??
Thanks in advance for the info.
Old Sep 18, 2003 | 05:23 PM
It is the vacuum feed from the TB to the EVAP solenoid. You need it fixed.
Old Sep 18, 2003 | 05:47 PM
Z28Boss's Avatar
Thanks Shoebox . Could that be what is causing my rough idle??
Old Sep 18, 2003 | 05:55 PM
It's possible. Any vacuum leak will upset what the computer is trying to do. It can compensate to some degree.
Old Sep 18, 2003 | 06:00 PM
Z28Boss's Avatar
Is there any way I can test to see if thats what is causing it without going out and buying that piece. Like a temporary fix or something??
Old Sep 18, 2003 | 06:03 PM
Simply plug the port on the TB. The EVAP won't have any flow and you might get a code or two, but there will be no leak.
Old Sep 18, 2003 | 06:29 PM
Z28Boss's Avatar
Ok, I will probably just go buy the new elbow and see if it works instead of messing with possible codes being thrown. If that doesnt take care of it, any idea what else it could be. I have replaced the opti and IAT sensor. I have cleaned my TB and cleaned my IAC really good. I dont know what else to try!! Any ideas you have would help, you seem to know your stuff from other things I have read on here.
Old Sep 18, 2003 | 07:03 PM
Not everyone has the capability, but the best way to know what is going on with your car is to look at it with a scanner or data logging software. If you can do that and learn what it all means, you be able to diagnose and fix most issues.
Old Sep 19, 2003 | 06:56 AM
Z28Boss's Avatar
I have a laptop and some diagnostic software, I just need the cable to connect the laptop to the car, I will probably have to get that. Thanks for the help!
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
MDZ28
11
Sep 24, 2015 09:15 AM
NewsBot
Sep 14, 2015 09:20 AM
