errr umm... so what happens if you run without an air filter?
K&N FIPK air filter fell off most likely when i bled my brakes about 2 or 3 weeks ago. didn't realize it till today.
i cleaned the MAF and the air temperature sensor, what else may be a side affect of running w/o an air filter for a somewhat extended period of time?
the MAF screen is still in BTW
It doenst apply to K&N Cold Air intakes....
j/k dude. You see you get dust particles going into your cylynder walls... scratching here and there and if bad enough eventually allowing oil past the rings..... most dust will burn up but the largest particles are bound to do some scratchin...
Just put the filter back on and find a way to secure it more properly....
Marvin
The only effects will be long term. If you did not drive in particularly dusty conditions, you probably don't have much to worry about. You can't do anything about it now, so no sense in fretting.
