Shifter hangs?
Old Sep 19, 2003 | 02:41 PM
ZZtop's Avatar
Shifter hangs?
My car has 104k miles on it and when I shift there is a brief stop or hang in neutral. This is there no matter what gear I am shifting to. It really makes shifting quick at the track tough. Its like when I go to shift it goes click(neutral) click(gear). How do I make it glide right through neutral and into gear?
Old Sep 21, 2003 | 06:12 PM
ZZtop's Avatar
Is there a place to grease the shifter or what? my buddies Camaro does not hang like this.
Old Sep 21, 2003 | 06:28 PM
Blue89Bird's Avatar
the stops on the t56 are internal as opposed to being adjustable through the shifter, yours may be jacked up from 100k of abuse and causing the problems you refer too.
Old Sep 30, 2003 | 11:02 PM
ZZtop's Avatar
The guy I bought it from babied it, is there anything else that could cause this? Its driving me nuts, but Im not positive a Pro 5.0 will eliminate the problem if its internal.
Old Oct 1, 2003 | 01:26 AM
Fastbird93's Avatar
The T-56 is notchy to begin with. If you're trying to get a butter smooth shift between gears, I don't think it's going to happen. I've had three cars with the T-56, one of which was brand new, and they all felt the same.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
