Door Sags, help please
Old Sep 19, 2003 | 07:07 PM
WhiteBeast's Avatar
Hello,
My door on my trans am has sagged down so much that you have to pick it up to close the door. Would this be a result of the pin or something else. Also where can i find a door pin?
Old Sep 19, 2003 | 07:08 PM
94 CAMRO Z28's Avatar
Im not sure about on our cars, but my brother had the same problem on a cougar, he was able to buy a couple little shims real cheap that fixed the problem.
Aaron
Old Sep 19, 2003 | 07:32 PM
carlos64030's Avatar
On our cars the doors are HEFTY-HEFTY-HEFTY, supported by wimpy-wimpy-wimpy door hinges that tends to fatigue over time. Replace the door hinge.
Old Sep 26, 2003 | 05:24 PM
WhiteBeast's Avatar
Ok, I have found out why the door is sagging. It looks like the actuall skin of the door is pulling away from the hinges. So how am i suppose to fix this? Could i possibly put some sort of washer between the door and the hinge to possibly raise it?
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
