Wierd Screech
Old Sep 18, 2003 | 03:43 PM
GrayPurpleTA's Avatar
Post Wierd Screech
I got this problem ever since I owned a car. When my car would shift from 2nd into 3rd, it would make a screeching sound. At first I used to think that it was transmission problems. Eventually I blew the stock trans and had it rebuilt. The car made the same sound. A week later it managed to mess up again. So this is my third trans and the car still makes the same sound. I got to the conclusion that its not the trans which is making this sound. Some one suggested that it could be pulleys/belt. I changed the belt about 8 months ago. Any ideas?
Old Sep 18, 2003 | 05:03 PM
TobyZ28's Avatar
Belt.
WhiteThunderZ28's Avatar
it might be you belt tensioner cause i took of my belt tensioner pulley to do so work and when i put it back on i must of tightned it to much, so i started the car i got a real loud screeching soi turned the car off and lossed the nut a little bit and it was fine.
Now if it still does it, take some belt dressing and use it on the belt and see what happens.
Old Sep 18, 2003 | 06:16 PM
Cool. Would a new set of underdrive pulleys help this. What are the best pulleys?
Old Sep 18, 2003 | 07:18 PM
Underdrive pulleys won't help the belt screech. Get a new belt (like a Goodyear Gatorback) and see if it stops. If not, change the belt tensioner.
Old Sep 18, 2003 | 07:48 PM
What does the tensioner look like? Is it hard to change it?
Old Sep 18, 2003 | 08:00 PM
It about 5 1/2 to 6" round and has 1 bolt going in the middle.
If you go underneath the car it will be to the left of the crank hub and right of the AC compressor..
I didnt need a jack to do it , i got underneath the right front side of the car and did it BUT you might need to jack it up if you cant get it loose, it's only arms lengths away.
Old Sep 18, 2003 | 09:05 PM
I am looking at chiltons right now, and it looks like the tensioner pulley is adjustable. Can I adjust it or do I have to get a new one? Checked the belt, and its in good condition.
Old Sep 18, 2003 | 09:11 PM
Just unscrew the bolt a little loose not much or after you break it loose then try it, DONT loosen it up all the way it may fall off.
The tensioner puts tension on the belt from a spring inside the housing i beleive.
Old Sep 18, 2003 | 09:58 PM
I don't believe the tensioner is adjustable. Plus, belts can look good all day long and still screech. It's really hard to tell about a belt.
Old Sep 18, 2003 | 11:35 PM
I don't know who made my belt (probably some cheapo crap), but when I the old one with it, it still screeched. Any ideas?
93RedDevilZ28
May 17, 2003 10:06 AM
OffspringZ28
May 8, 2003 10:44 AM
djgerry
Mar 9, 2003 08:53 PM
mosskeet
Mar 5, 2003 09:34 PM
eddiezlt1
Feb 14, 2003 05:36 PM
