Major problems past 4000rpms. HELP!
My car is really starting to become a pain in the ***. Over the past few days every time I give it gas past 4000rpms its almost like it goes into neutral. It makes absolutly no power and revs much faster than normal up to 5900rpms.Up to about 3300 rpms that car acts perfectly normal though. It seems like the engine is operating fine but the tranny or something is not able to get the power to the rear wheels. Can someone help and tell me what this could be?
I agree it sounds like the trans try pulling it down into first gear and then manually moving it into second. See if it still does it. Could be the OD sprag is hosed or that the line pressure is down. Pulling it down to 1st should up the line pressure and keep it from putting pressure on the OD sprag.
