Water Pump Seal
Old Sep 20, 2003 | 10:05 AM
93ZM6Tally's Avatar
Water Pump Seal
Is the water pump driveshaft seal a dealer only carried item. I of course tore mine and it's Saturday, dealer parts counters are closed. Anyone have any luck finding one at local parts houses and if so what did you use to find it. So far none of them can cross the AC Delco or GM number.
Thanks.
Old Sep 20, 2003 | 10:07 AM
AsianSensation's Avatar
It's a GM/AC Delco part.
Old Sep 20, 2003 | 10:53 AM
PoorMan's Avatar
It comes with the Felpro timing gasket set. About 15 dollars though. Most Auto parts store sell this set.
I have a pic of it in my sig.
Jeff D.
Old Sep 20, 2003 | 11:19 AM
Bud M's Avatar
Are you sure dealer parts counters are closed? My local Chevy dealer's parts counter is open on Saturday.
Next time you try to install that seal, stretch out the center or use something to help it get up over the lip on the shaft.
Old Sep 20, 2003 | 11:26 AM
JBirdSS's Avatar
This thread might be of help to you.
http://web.camaross.com/forums/showt...ight=opti+seal
Old Sep 20, 2003 | 08:03 PM
revtime's Avatar
Follow JbirdSS advice and it should work for you.
I too trashed the first seal I tried to install and used his advice on the second one and it went right in there.
I could only find them at the dealer.
Old Sep 20, 2003 | 09:35 PM
93ZM6Tally's Avatar
Jeff D.
Thanks Jeff. I actually found a parts guy who was willing to actually do some leg work and found the kit. And JBirdSS your method worked like a charm. Thanks all.
Old Sep 22, 2003 | 01:45 PM
93ZM6Tally's Avatar
BTW. Just for the record. I did get this seal on properly without any tearing, but that has to be the most tedious BS gasket/seal that I've ever seen.
The engineers who come up with this stuff should have to replace every part that they design themselves - before the part is put into production.
This seal is a JOKE!
Old Sep 22, 2003 | 11:43 PM
SinisterSS's Avatar
What the heck does it actually seal anyhow? No oil can possibly get through there....
Old Sep 23, 2003 | 12:42 AM
InjectedSS's Avatar
HAHAHAHH yea you would think
dude that effin seal leaks more than if i were to loosen my oil drain plug i ain't gonna lie that thing is GHEY AS FAWK!!!!!!!!
i put an electric waterpump on JUST so i could BYPASS the waterpump shaft seal all together, that's how annoying that thing is...
good luck installing that thing man, you've got more patience than me i can tell ya that...
Old Sep 23, 2003 | 12:58 AM
Transamdriver's Avatar
You can see how I bypassed the seal, 2 1.25" washers and a bolt and nut.
Old Sep 23, 2003 | 03:20 AM
InjectedSS's Avatar
yea that works too... i seen that page when i was going to bypass mine.. i actually found a pipe plug that fit in there perfect, and then i just sealed her up with some copper sealant and VLOIA NO MORE HASSLE
Old Sep 23, 2003 | 10:26 AM
SinisterSS's Avatar
You guys must be talking about the seal pressed into the timing cover eh? My cunundrum is the little o-ring on the shaft, wtf is that for anyhow? Keep dirt out of the splined coupling perhaps?
Old Sep 23, 2003 | 03:57 PM
93ZM6Tally's Avatar
Kinda wondered about that myself. I remember someone saying something about it "cushioning" the impact of the two male portions of the shaft coupling.
Reading that sounds like a porno film script.
Old Sep 23, 2003 | 07:16 PM
That's what I would think it was for. You should dab a little grease on the shafts/coupling before putting it together.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
