Bmr tunnel brace question
Old Sep 18, 2003 | 10:34 PM
1msfyter's Avatar
Anyone that has one, did you have to use longer bolts? also looking at it each side is different
(angle of the bracket)I havent gotten under the car yet to check.
Old Sep 19, 2003 | 07:19 PM
Bud M's Avatar
The BMR brace is probably made from 3/16 steel so the difference between it and the stock brace should not require different bolts. I would be curious to know if it makes a noticeable difference and if it gives you more or less ground clearance.
Old Sep 19, 2003 | 07:41 PM
1msfyter's Avatar
I install in the morning , will post the results if its lowere or what.
Old Sep 19, 2003 | 11:34 PM
QCKZ28's Avatar
i have KB dd sfc, and when i installed my lakewood driveshaft loop. (it bolts in where the tunnel brace does) i had to have longer bolts, about 1/4" inch i believe.
Old Sep 20, 2003 | 04:52 AM
revtime's Avatar
Yes DDs will require longer bolts, otherwise the stock ones will be fine.
On my car I did lose some ground clearance as the Gload brace became the lowest point on my car.
Old Sep 20, 2003 | 09:37 PM
1msfyter's Avatar
The BMR brace fit perfect, the bolts were long enough. BUT the BMR brace hangs lower than the stock one. My car has DMS springs and is 1.5"lower. Yes I scrape
On the plus side I honestly think it tightened up and tied together my sub frames much better.
8T8IROC
Mar 26, 2015 09:02 PM
Fusion93Z
Sep 10, 2002 06:46 PM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
