hotcam vs cc305
Old Sep 18, 2003 | 01:43 PM
mickeyiz28's Avatar
hotcam vs cc305
can someone tell me which cam makes the most hp, and which one is safer on the engine, i just turned over 100k
Old Sep 18, 2003 | 01:53 PM
94Zpower's Avatar
I am no Cam exoert but I was under the assumption that they are very similar and their is not much difference in the #'s
Old Sep 18, 2003 | 01:54 PM
FacelessZ's Avatar
search function
Old Sep 18, 2003 | 01:55 PM
americanmusscle's Avatar
the cc305 makes a more horsepower but I belive it is not emissions leagal. The hot cam is a good cam also but some say it is not as good as a 305 or a 306. They both are good cams to toss in your engine even though its over 100k miles. You might want to think about changing out your RR when you do the cam install and the springs to go with the correct cam you will be putting in. The hotcam is also emissions leagal and can be tuned to your specifications so its all up to you on which one you like.
Old Sep 18, 2003 | 02:07 PM
mickeyiz28's Avatar
im gonna put new springs, rockers, and pushrods when i do the switch, and i live in kentucky where they dont have any emissions
Old Sep 18, 2003 | 02:10 PM
AndyB's Avatar
Originally posted by americanmusscle
the cc305 makes a more horsepower but I belive it is not emissions leagal....The hotcam is also emissions leagal and can be tuned to your specifications so its all up to you on which one you like.
Technically neither one is CA smog legal. However both of them have passed smog in Ca before.
In theory the Hot cam would actually be more difficult to pass a smog test due to its 112 LS. A narrower LS will have more over lap and allow a dirtier tail pipe emmissions than that of a wider 114LS.
I am currently running the CC305 in my 100k mile LT1. AS soon as I get a better tune on it I am going to take it down to the smog shop and see if it will pass CA strict Dyno testing
Old Sep 18, 2003 | 02:14 PM
350 HRSS's Avatar
The hot cam is a little milder than the 305. The 305 does have a little more HP to offer. If you have an A4 car and you get the 305
you may need a convertor. I did w/ the hot cam kit alone.
Also, w/ the hot cam, you can get away w/o a tune. Usually. I am not sure if the 305 is as well-mannered w/o tuning.
Good luck! Depends what YOU want...
Old Sep 18, 2003 | 02:34 PM
GREGG 97Z's Avatar
Re: hotcam vs cc305
I don't think one is safer on the engine than the other, it all depends how hard you drive with either one. They are very similar cams, I've heard the 305 can make slightly more hp. I went with the hotcam kit mainly for the price and being that it was a complete package.
Old Sep 18, 2003 | 02:48 PM
I would like to know if you pass or not too. If you pass i might have to think about a 305 instead of a hotcam. Give me a heads up. thanks.
Old Sep 18, 2003 | 04:35 PM
12SCNDZ's Avatar
I love my CC305...And, yes it is emissions legal.
Frank
Old Sep 18, 2003 | 04:43 PM
BPS's Avatar
BPS
As gregg said - hot cam is a good pick cause it comes as a complete package (well tested by board members) at a really good price.
To me, that fact was worth, maybe giving up, a couple of Hp at 6000 rpm.
If you don't mind mixing and matching parts - there are better cams out there then the 2 you mentioned, that you may want to consider - depends on current and planned mods.
With over 100K on the car you may run into some cam bearing issues.
Old Sep 18, 2003 | 04:46 PM
BOWTYDE's Avatar
Well more hp and safer for the engien are two diffrent thing, not changeing the cam is going to by safter for the engien.
The CC305 is a bigger cam then the hotcam, and dosen't cost very much more (if any), if you buy the hotcam in 3 months your going to wish you bought the CC305.
Just remember, when your are trying to suck more power out of your engien it is going to put it under for stress, and there for shorten the life.
Old Sep 18, 2003 | 04:48 PM
AndyB's Avatar
Hey Steve-o
someone else from Roseville. Have you smogged your CC305 yet on the Dyno Emissions tester?
Old Sep 18, 2003 | 04:49 PM
Teal94Z's Avatar
Please do a search, there are several long and informative posts comparing these 2 cams....
Old Sep 18, 2003 | 04:55 PM
JohnsSS's Avatar
220 / 230, .510 / .510 114 LSA = cc305
218 / 228, .492 / .492 112 LSA = hotcam
lift numbers change with different size rockers, most people that I know swith 1.6's if they do a hotcam with changes that cam to:218 / 228, .525 / .525 112 LSA ...without the rockers the cc305 will make considerably more power than the hotcam and it will be a lower power band.
my numbers were gotten from here
http://www.thunderracing.com/index.c...ategoryid=1107
