Help with Cooling Fans
Lastnight I was out in my car and the temp was around 210-220 and I noticed 1 fan was running well a few mins later it got hot 240-260 =( because it was low on water but the 2nd fan never came on =( and now I want to be able to turn the fans on either with a switch or when the key is on so if this is possible please let me know. Also How can i check the fans to make sure they both work??
P.S. I looking for someone to help Tune my car prefer Dyno tuned but I do have a laptop and the cables. If you can help me please let me know and I will sent you a list of everthing done to my motor.
Thanks alot
Thanks alot
yea id like to know how to keep them on whenever the car is on... that would be nice...
cause mine will heat to 235... not blistering hot but too hot for my comfort.
but i donno if i want to be under a car that is cranked up while the engine is running...
scarry
scarry
Letting your car get to 235 degrees isn't exactly the best thing for it. There are basically two directions you can go to keep the car cool. I spent $18 and got a 160* thermostat, and adjusted the cooling fans with the HppIII my friend is letting me borrow. Pcmforless.com or Madwolf can tune your PCM for lower running temps too. The other way is to buy a manual fan switch (SLP) for like $60, and you can run the fans on low/high whenever you want. Do a search...tons of info
Just put in a manual fan switch, i love mine.. dont go paying $70 or whatever SLP sells them for.. if you can wire in a stereo you can do the fan switch.. its about $15 worth of parts from Radio Shack. Piece of cake!
Craig
Craig
Thanks for the help
I do have a 160 stat in it but the computer is all stock right now I had a HPPIII but sold it and bought the cables and laptop now I just need help on how to tune it. I have TunerCat but its been 2 yrs since it was used and the program dont work I have to see if they will give me another key.
Thanks alot
Jimmy
I do have a 160 stat in it but the computer is all stock right now I had a HPPIII but sold it and bought the cables and laptop now I just need help on how to tune it. I have TunerCat but its been 2 yrs since it was used and the program dont work I have to see if they will give me another key.Thanks alot
Jimmy
hey guy, i would just go with a fan switch. its pretty quick and simple and cheap. shoebox has a guide on how to hook it up real quick and that way you can turn both high and low on and off as you please. even without the car running. nice feature at the track.
Originally posted by 96chargedRamAir
Thanks for the help
Thanks alot
Jimmy
Thanks for the help
Jimmy
Originally posted by NewbieWar
is there any way to have them go on whenever the cars on without a switch?
If you were low on water and running high temps you probably have another problem other then the fans. I'd start by draining the system and refilling it with the recommended 50/50 mix and be sure to open the valves so you dont get air in the system
Noct
Jul 14, 2015 01:18 AM
