12-bolt swap
Old Sep 19, 2003 | 04:47 AM
93FBIRDFORMULA's Avatar
Exclamation 12-bolt swap
I had the stock rear with 2.73 gears and I just upgraded to a Moser 12-bolt assembly with 3.73 gears.
My problem is that after I go faster than about 73 mph the ABS INOP light on the instrument cluster goes on and then it will go out when the car is shut down and then restarted, but then the same will happen at 73 mph again.
Anyone with any ideas?
Old Sep 21, 2003 | 08:37 PM
does anyone have any info about this problem?
Old Sep 21, 2003 | 09:38 PM
Z95m6's Avatar
try calling moser.
Old Sep 21, 2003 | 09:44 PM
97 RedSS's Avatar
You did swap your old ABS sensor to the new rear-end correct? Maybe they didnt have the ABS option in your rear-end from Moser???
Cody
Old Sep 21, 2003 | 09:46 PM
1Z2Z's Avatar
Is your chip reprogrammed for the new gear ratio?
Old Sep 23, 2003 | 04:15 PM
I ordered the rear from Moser with ABS option and I am pretty sure that the sensor from my old rear was properly installed into the new rear.
As far as the computer chip, why would it have to be reprgrammed?
I have the TH-700-R4 trans and I did not have to alter the shifting by changing the springs and weights in the govener and I recallibrated the speedometer by swapping out the drive and driven gear set.
Is there any other reason the chip needs reprogramming?
Old Sep 23, 2003 | 05:27 PM
LT1TONY's Avatar
Try cleaning the sensor, maybe there's some metal shavings or something. Did you clean it before you put it in? Check your wire too.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
